with the same link, PC is fine, but C851 has regular packet loss
behigh
Dear all,
RT, it's very strange. Did any one meet that situation please?
Internet----Gateway(Cisco router)----CiscoSwitch----My end point
When my end point is a PC connected, and ping to the gateway, it's fine. But when it switched back to the C851, after ping the gateway, the return of !!!.!!!.!!!.!!!.!!!.!!!.!!!.!!!.!!!.!!!.!!!.!!!.!!!.!!!.!!!.!!!.!!!.!!!.!!!.!!!.!!!.!!!.!!!.!!!.!!!.!!!., with 25% loss happened.
and I really don't know how could that happened.
Thanks for your kind Tips in advance.
Giuseppe Larosa
hello Hai,
if I understood correctly if the PC is directly connected to the C851 you get 100% success if there is the switch in the middle you get 75%.
What is the Cisco switch ?
verify the statistics of involved switch ports (the one to the PC and the one to the router)
or are you using a C851 like a switch ?
use
show int fas0/x
check if there are errors.
and if they increment accordingly to your losses.
verify the duplex and speed settings on all devices : PC NIC, Router Lan port, the two switch ports
Hope to help
Giuseppe
