WLC2504-AP1532 Connection and configuration
sarode.rahul
I have a scenario, I have 2504 WLC , 1532 Cisco AP and Cisco 2960 PoE switch and I need to configure WLC Management IP & Cisco 1532AP in different network subnets where AP should get the IP Automatically from WLC. I need to connect WLC & 1532AP through 2960 switch.
Management IP (10.10.10.1) and APs should be in 20.20.20.2-10
Can you please help me to configure the same at all end.
Attached scenario for reference
Thanking you in advance
 You can't with this switch model. To keep AP in a different IP range of wlc management Interface you need to perform inter vlan routing, so, you need to have a layer 3 device to do that.
 On the layer 3 device you can create an interface vlan for APs and add the command  helper address pointing to the WLC interface so that they can get an IP address.
-If I helped you somehow, please, rate it as useful.-
As far as I recall. you cannot use the PoE ports on the 2504 to directly connect an AP.
