Show processes cpu history command not taking in nexus 5020
BhaskarDS
End client having Nexus 5k switch. And they want to check the CPU history for last 72 hours. But the command "Show processes cpu history" is not taking.
Model -N5K-C5020P-BF-SUP
Version - 4.1(3)N2(1a)
Can anybody help me in this ? Is it something related to the IOS version ?
I see this model should support this command.
Keep in the mind, spikes of high CPU utilization on the Cisco Nexus is a normal activity. Viewing the CPU history is valuable when correlating a network event with the past CPU utilization.Cisco NX-OS takes advantage of CPU multitasking, so processes can take advantage of an idle CPU to complete tasks faster. Therefore the show process cpu history command might display CPU spikes that are not necessarily a problem.
Additional investigation is required if the average CPU remains close to 100%. If you have a logging level setting, such as 6, many messages are generated and performance can be impacted, try change the logging level on the chassis check if your system performance is significantly slower or non responsive if YES raise a TAC with Cisco to additional investigation
