Would you please tell me about IP SLA ?
Takuro Moriyama
Hello Expert,
I would like to shut down the interface by IP SLA.
I investigated by google teacher.  The google theacher said that the EEM can it.
But, I don't want to use the EEM.  If possible, I want to use only the IP SLA.
The following example use the EEM. Are there any other way?
example)----------------------------------------------------------------------------------------------------
ip sla monitor 1
  type echo protocol ipIcmpEcho 10.110.0.1
  tos 184
  timeout 10000
  frequency 15
ip sla monitor schedule 1 life forever start-time now
track 1 rtr 1 reachability
delay down 20 up 20
event manager applet shutdown-f0/0
event syslog pattern "%TRACKING-5-STATE: 1 rtr 1 reachability Up->Down"
action 1.0 cli command "enable"
action 1.1 cli command "conf t"
action 1.2 cli command "interface  FastEthernet0/0"
action 1.3 cli command "shut"
event manager applet noshutdown-f0/0
event syslog pattern "%TRACKING-5-STATE: 1 rtr 1 reachability Down->Up"
action 1.3 cli command "no shut"
Takuro.
cadet alain
The only way to do this is either with  EEM  or with a Tcl script but surely not with IP sla  alone.
Regards.
Alain.
cadet alain
Regards.
Alain.
Thank you for advice.
Thank you again for your kindness.
Regards.
Takuro,
You should tell us what you want to achieve. Perhals your problem can be solved with something else. Or a simple tracking-config could also be enough.
