WRED and queue depths
tony_brown
Hi All,
My understanding is that each CBWFQ class in a policy-map has a default output queue depth of 64, which is also the MAXIMUM queue depth.
However, if this is the case, how can the following WRED command be referring to a max threshold value of 100 packets?
random-detect dscp af 13 25 100 4
Thanks in advance!
cadet alain
I think this is because as long as you enter a number taken by command( from min threshold to 4096) then the command is accepted.
Regards.
Alain.
