Wrong value of BGPDstOrigAS in IPv4 flows
Denis.zm90
I have configured NetFlow version 9 on an NCS 5500 series router, and I'm noticing that flows destined to my network show BGPDstOrigAS = 0
flow exporter-map EXP-MAP
version v9
options interface-table
options sampler-table
transport udp 2055
source Loopback0
destination xxxx
flow monitor-map xxx
record ipv4
option bgpattr
exporter  EXP-MAP
cache timeout active 60
Mark Elsen
           -  FYI https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwd54397
  M.
Giuseppe Larosa
Hello @Denis.zm90 ,
netflow accounting can classify using the peer AS or the origin AS. when using peer-AS that is default 0 means your own AS number. You should be able to revert to origin AS mode with a command.
Hope to help
Giuseppe
Denis.zm90
@Giuseppe Larosa how to revert to origin AS mode ?
