Showing results forĀ
Search instead forĀ
Did you mean:Ā
WRT300N Can't ping to router or laptop from wired PC & vice versa.
0x01337
I know this seems like a super beginner issue, but I'm not sure if my configuration is wrong or something.
PC won't work w/ DHCP and whenever I ping the gateway 192.168.0.1 It fails.
Same w/ pinging the laptop @ 192.168.0.100/24
Am I doing something wrong?
I haven't changed the routers config or anything.
5 Replies 5
post the zipped Packet Tracer project (.pkt) file here...
I think the DHCP for the PC only works when you install a wireless module in the PC (see attached file)...
It does work when the wireless module is added, but this is just a test for a school project and it's required that there is a wired computer and wireless device that are able to talk to each other.
what are the exact requirements ? Can you put a router between the switch and the wireless router ?
No i'm not able to, everything is connected to either the switch or wirelessly to the router.
