Showing results forĀ
Search instead forĀ
Did you mean:Ā
WRVS4400
erik.bullens
i have  a problem with my 4400 router. i have a fixed ip of my provider and the router gets this from my cable modem.
But when i try to ping the ip addrress from provider i have no reply.
I need this for a vpn connection .
Can anyone help?
fb_webuser
Level 6
Level 6
And what does happen if you connect PC directly to cable modem? Is ping OK?
Posted by WebUser Aleksandr Yanovskiy
When I connect the cable modem to my pc the ping is ok
fb_webuser
Level 6
Level 6
Will yout router be VPN server or only forwarding traffic? Cheack your firewall first
