WS-C2960L-SM Visio Stencils?
sergef1973
I have not been able to find the stencils for a 2960L series. Can someone help?
6 Replies 6
FYI
See attached ....
Kind Regards
Paul
This file does not include 2690-L series switches. I had downloaded it before.
Hello
I made my own, unfortunately it is only for WS-C2960L-24PS-LL.
Greetzz
Where Visio Stencils C2960L-SM  2018???
If anyone needs a 48 port version, here you go. As a warning this is the first stencil I've edited and I did it pretty quickly. Seems okay though, better than nothing, right?
May not be needed, but since I had to do a re-design and there were alot of this type, I made a quick effort from scratch for my purposes, like Will, I am no expert, but I will add to the cause.
If people don't want the rack ears, just ungroup once, delete the background.
I named them simploy 8, 16, 24, 48 TS and PS (POE) include some back versions for normal and compact form factor
They are I think to scale-ish, I used mm sorry about that, one issue I think there is the text at the far right doesnt shrink properly, but I don7t know how to fix that. maybe someone than me can, as I said, I made them for my purposes.
