WS-C2960X-24TS-L OSPF
ibrkic001
Hello.
Can Cisco Switch  WS-C2960X-24TS-L support full OSPF protocol,  with software 15.2(6) E ,or with some other release ? I read somewhere that supports a limited number of dynamic routes.
Giuseppe Larosa
Hello @ibrkic001 ,
according to the datasheet that you can find here
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/datasheet_c78-728232.html?dtid=osscdc000283#ProductOverview
A change of feature set is not possible:
All Cisco Catalyst 2960-X and 2960-XR Series Switches use a single universal Cisco IOS Software image for all SKUs. Depending on the switch model, the Cisco IOS image automatically configures the LAN Lite, LAN Base, or IP Lite feature set.
>>Note that each switch model is tied to a specific feature level; LAN Lite cannot be upgraded to LAN Base, and LAN Base cannot be upgraded to IP Lite.<<<<<<<<
For more information about the features included in the LAN Lite, LAN Base, and IP Lite feature sets, refer to Cisco Feature Navigator: https://tools.cisco.com/ITDIT/CFN/jsp/index.jsp.
Likely are the C2960-XR the devices with IP Lite that support OSPF . your device should have LAN base according to the datasheet.
I cannot access feature navigator at the moment it is the tool that can tell if OSPF is supported or not.
Hope to help
Giuseppe
Giuseppe Larosa
Hello @ibrkic001 ,
Hope to help
Giuseppe
