WS-C3560-48PS port going up and down
singhaam007
Level 3
Level 3
one off our switch showing in logs
000895: Feb 20 12:02:26 NZDT: %LINK-3-UPDOWN: Interface FastEthernet0/16, changed state to up
000896: Feb 20 12:02:28 NZDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/16, changed state to up
000897: Feb 20 12:02:46 NZDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/16, changed state to down
000898: Feb 20 12:02:47 NZDT: %LINK-3-UPDOWN: Interface FastEthernet0/16, changed state to down
000899: Feb 20 12:02:50 NZDT: %LINK-3-UPDOWN: Interface FastEthernet0/16, changed state to up
000900: Feb 20 12:02:52 NZDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/16, changed state to up
000901: Feb 20 12:03:09 NZDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/16, changed state to down
000902: Feb 20 12:03:10 NZDT: %LINK-3-UPDOWN: Interface FastEthernet0/16, changed state to down
000903: Feb 20 12:03:13 NZDT: %LINK-3-UPDOWN: Interface FastEthernet0/16, changed state to up
000904: Feb 20 12:03:15 NZDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/16, changed state to up
000905: Feb 20 12:03:32 NZDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/16, changed state to down
000906: Feb 20 12:03:33 NZDT: %LINK-3-UPDOWN: Interface FastEthernet0/16, changed state to down
000907: Feb 20 12:03:36 NZDT: %LINK-3-UPDOWN: Interface FastEthernet0/16, changed state to up
000908: Feb 20 12:03:38 NZDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/16, changed state to up
000909: Feb 20 12:03:55 NZDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/16, changed state to down
000910: Feb 20 12:03:56 NZDT: %LINK-3-UPDOWN: Interface FastEthernet0/16, changed state to down
000911: Feb 20 12:03:59 NZDT: %LINK-3-UPDOWN: Interface FastEthernet0/16, changed state to up
000912: Feb 20 12:04:01 NZDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/16, changed state to up
000913: Feb 20 12:04:18 NZDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/16, changed state to down
its just keep going after some time switch reboot it self and reboot status showes
Last reset from address error
is this a bug ?
thanks
Leo Laohoo
Post the following output:
1.  sh interface F0/16; and
2.  sh controll e F0/16
please see below
#sh int f0/16
FastEthernet0/16 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 0018.184e.0392 (bia 0018.184e.0392)
  Description: USER VOICE/DATA PORT
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 3000 bits/sec, 4 packets/sec
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     24810 packets output, 3226551 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
#sh controllers ethernet-controller f0/16
     Transmit FastEthernet0/16                Receive
      3234001 Bytes                                0 Bytes
         1968 Unicast frames                       0 Unicast frames
        12173 Multicast frames                     0 Multicast frames
        10755 Broadcast frames                     0 Broadcast frames
            0 Too old frames                       0 Unicast bytes
            0 Deferred frames                      0 Multicast bytes
            0 MTU exceeded frames                  0 Broadcast bytes
            0 1 collision frames                   0 Alignment errors
            0 2 collision frames                   0 FCS errors
            0 3 collision frames                   0 Oversize frames
            0 4 collision frames                   0 Undersize frames
            0 5 collision frames                   0 Collision fragments
            0 6 collision frames
            0 7 collision frames                   0 Minimum size frames
            0 8 collision frames                   0 65 to 127 byte frames
            0 9 collision frames                   0 128 to 255 byte frames
            0 10 collision frames                  0 256 to 511 byte frames
            0 11 collision frames                  0 512 to 1023 byte frames
            0 12 collision frames                  0 1024 to 1518 byte frames
            0 13 collision frames                  0 Overrun frames
            0 14 collision frames                  0 Pause frames
            0 15 collision frames
            0 Excessive collisions                 0 Symbol error frames
            0 Late collisions                      0 Invalid frames, too large
            0 VLAN discard frames                  0 Valid frames, too large
            0 Excess defer frames                  0 Invalid frames, too small
         7011 64 byte frames                       0 Valid frames, too small
        14024 127 byte frames
         1056 255 byte frames                      0 Too old frames
         2474 511 byte frames                      0 Valid oversize frames
          259 1023 byte frames                     0 System FCS error frames
           72 1518 byte frames                     0 RxPortFifoFull drop frame
            0 Too large frames
            0 Good (1 coll) frames
            0 Good (>1 coll) frames
Possibly your NIC is faulty.
I can see ONE-WAY traffic. Switch port is sending data downstream but downstream client is not responding.
