WS-C3750E-48TD with WS-C3750G-12S
doesterhuizen
Good Day All
I was wondering if I can stack WS-C3750E-48TD with WS-C3750G-12S together to created a single logical switch.
Not sure where to find the info with reagrds to which models can be stacked together.
Collin Clark
From the 3750-E Q&A
Q. Can I run Cisco Catalyst 3750 switches with Cisco Catalyst 3750-E switches in the same stack?
A. Yes, the two series are compatible. When the Cisco Catalyst 3750-E Series detects a non-E-Series Cisco Catalyst 3750, it will negotiate down from StackWise Plus mode to StackWise mode. Thus, the entire stack will now run in the original StackWise mode.
Leo Laohoo
To add to Colin's post, yes you can.
But understand that the 3750G-12S has a small flash memory.  This means that the 3750G will not be able to run higher IOS that the "-E" can.  The highest IOS the 3750G-12 can run is 12.2(55)SE (and higher).
I would recommend your stack to load IOS version 12.2(55)SE6.  Do NOT use other IOS versions other than this as this train is the most "stable" of them all.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Another caution, the G-12S supports a SDM template, not available on other models.
