WS-C3750G-24T-S stacking
BashedRoot
Level 2
Level 2
So I have a WS-C3750G-24T-S switch and I want to know something:
What is needed to be configured once I connect first stacking cable, and second?
Does this ease the load CPU and RAM load, by balancing between the 2 switches with 2 stacking cables plugged?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Normally, a 3750 does not require any special configuration to use its stacking cables.  As you add stack members, stack members supply what appears to be just another set of ports that can be configured (much like when you add a line card to a chassis switch).
CPU and RAM are not aided by the addition of a 3750G stack member.  If fact, with StackWise, every stack member floods all its traffic to the stack cables.  I.e. adding stack members can actually create a performance issue that you might not see keeping the switches non-stacked.  However, the other advantages of stacking 3750s, and the bandwidth of the stack cables usually offsets the issue of stack units, except perhaps in very busy or very large stacks.
BTW, StackWisePlus, used on the 3750-E and 3750X, has twice the stack bandwidth and uses the stack cables much "smarter" than StackWise on the 3750 or 3750G.
