WS-F6700-DFC3BXL
Hi Dears
  I have router 7613 with IOS 12.2(33)SRE2 on it . I installed module  WS-F6700-DFC3BXL on it but the router cant recognized it.
  it shows unknown or after a minute power-off . and LEDs for module going to off.
  should I change the IOS ? and what is the better IOS for this router!?!
Mark Malone
looks like wrong IOS set
WS-F6700-DFC3BXL
http://www.cisco.com/c/en/us/td/docs/routers/7600/Hardware/12-2SR_supported_hw/7600_hwd.html
Product ID
(append "=" for spares)
Power
Required
Product Description
Minimum Software Version
WS-F6700-DFC3BXL
3.30 A@42 V
Distributed Forwarding Card 3BXL (DFC3BXL) for use on CEF720 modules
Supported only with Supervisor Engine 720
12.2(33)SRA
Note
WS-F6700-DFC3BXL uses memory that is installed on the switching module.
Refer to this publication for information about WS-F6700-DFC3BXL upgrades:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Config_Notes/78_15893.html
which IOS's , later than 12.2(18)SXD ?   is 12.2(33)SRE is higher or not?
SRE is higher than SRA, but I'm not sure how to compare 7600's SR* with 6500's SX* (in terms of ROMMON version requirement for the base line card)...
Anyway, how does "show module" look?  And which of the line cards do you wish to populate with that DFC? - maybe it doesn't have the latest firmware, and updating it to 12.2(18r)S1 could help...
