xconnect unresolved status in CRS Router
muchlas_raditya
I have a problem when creating xconnect from CRS router to 7606, the xconnect status always unresolved. The CRS and 7606 is directly
connected and here is the configuration :
 CRS Configuration
l2vpn
  pw-class test1
  encapsulation mpls
   transport-mode vlan
 xconnect group TESTXCONNECT
  p2p VLAN123_TESTXCONNECT
   interface GigabitEthernet0/0/2/7.123
   neighbor 1.1.1.105 pw-id 123
    pw-class test1
   interworking ethernet
 mtu 1518
 dot1q vlan 123
#sh int gigabitEthernet 0/0/2/7.123
Mon Dec  8 15:45:09.977 WIB
GigabitEthernet0/0/2/7.123 is up, line protocol is up
  Interface state transitions: 1
  Hardware is VLAN sub-interface(s), address is ccef.6f06.3021
  Internet address is Unknown
  MTU 1518 bytes, BW 100000 Kbit (Max: 100000 Kbit)
     reliability 255/255, txload 0/255, rxload 0/255
  Encapsulation 802.1Q Virtual LAN, VLAN Id 123,  loopback not set,
  ARP type ARPA, ARP timeout 04:00:00
  Last input never, output never
     0 packets input, 0 bytes, 0 total input drops
     0 drops for unrecognized upper-level protocol
     Received 0 broadcast packets, 0 multicast packets
     0 packets output, 0 bytes, 0 total output drops
     Output 0 broadcast packets, 0 multicast packets
 7606 Configuration
sh run int gigabitEthernet 1/43.123
Building configuration...
Current configuration : 114 bytes
interface GigabitEthernet1/43.123
 encapsulation dot1Q 123
 xconnect 1.1.1.223 123 encapsulation mpls
end
Verification
7606#show mpls l2transport vc 123
Local intf     Local circuit              Dest address    VC ID      Status
Gi1/43.123     Eth VLAN 123               1.1.1.223  123        DOWN
7606#traceroute mpls ipv4 1.1.1.105/32 source 1.1.1.223
Mon Dec  8 15:20:56.531 WIB
Tracing MPLS Label Switched Path to 1.1.1.105/32, timeout is 2 seconds
Codes: '!' - success, 'Q' - request not sent, '.' - timeout,
  'L' - labeled output interface, 'B' - unlabeled output interface,
  'D' - DS Map mismatch, 'F' - no FEC mapping, 'f' - FEC mismatch,
  'M' - malformed request, 'm' - unsupported tlvs, 'N' - no rx label,
  'P' - no rx intf label prot, 'p' - premature termination of LSP,
  'R' - transit router, 'I' - unknown upstream index,
  'X' - unknown return code, 'x' - return code 0
  0 1.1.1.162 MRU 9000 [Labels: implicit-null Exp: 0]
! 1 1.1.1.161 4 ms
CRS#ping mpls ipv4 1.1.1.105/32 source 1.1.1.223
Mon Dec  8 15:21:26.703 WIB
Sending 5, 100-byte MPLS Echos to 1.1.1.105/32,
      timeout is 2 seconds, send interval is 0 msec:
Success rate is 100 percent (5/5), round-trip min/avg/max = 3/4/5 ms
CRS#show l2vpn xconnect
Mon Dec  8 15:21:48.247 WIB
Legend: ST = State, UP = Up, DN = Down, AD = Admin Down, UR = Unresolved,
        SB = Standby, SR = Standby Ready
XConnect                   Segment 1                   Segment 2
Group      Name       ST   Description            ST   Description            ST
TESTXCONNECT
                      UR   Gi0/0/2/7.123          UR   1.1.1.105  123    UR
CRS#show l2vpn xconnect detail
Mon Dec  8 15:22:11.088 WIB
Group TESTXCONNECT, XC VLAN123_TESTXCONNECT, state is unresolved; Interworking Ethernet
Not provisioned reason(s):
        AC I/F not ready
  AC: GigabitEthernet0/0/2/7.123, state is unresolved
  PW: neighbor 1.1.1.105, PW ID 123, state is unresolved
any idea why the xconnect status is showing unresolved?
muchlas_raditya
this case is solved, you will get unresolved status if you didn't  add l2transport command in the interface, hopefully this post can help others who have same problem like me.
interface GigabitEthernet0/0/2/7.123 l2transport
 mtu 1518
 dot1q vlan 123
Thanks, this helped me.
Simple solution to a frustrating problem.
