XOT: fail to route incoming call with CUD=00
jpmarce
An incoming call received on an x25 serial interface is not routed over XOT as expected. The reason seems to be because the CUD contains a null NLPID i.e. the first byte is =00 in hex. Any other incoming call with a different CUD is routed over XOT. Below are the trace and the router configuration:
1.Here is the debug trace:
Router2#debug x25 int ser 1/6
X.25 packet debugging is on
X.25 debug output restricted to interface Serial1/6
*Apr 30 11:49:38: Serial1/6: X.25 I R1 Call (31) 8 lci 0
*Apr 30 11:49:38: From (9): 120030153 To (2): 44
*Apr 30 11:49:38: Facilities: (4)
*Apr 30 11:49:38: Behavior flags:
*Apr 30 11:49:38: no Reverse charging, no Fast select
*Apr 30 11:49:38: Closed User Group (basic): 00
*Apr 30 11:49:38: Call User Data (16): 0x00000000 (x25-multiprotocol)
*Apr 30 11:49:38: Address map failed
*Apr 30 11:49:38: Serial1/6: X.25 O R1 Clear (5) 8 lci 0
*Apr 30 11:49:38: Cause 0, Diag 68 (DTE originated/Invalid source
address)
*Apr 30 11:49:38: Serial1/6: X.25 I R1 Clear Confirm (3) 8 lci 0
2.Here is the router configuration:
version 12.1
no service single-slot-reload-enable
service pad to-xot
service pad from-xot
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime localtime
service timestamps log datetime localtime
hostname Router2
boot system flash slot0:c3620-is-mz.121-5.T
logging buffered 65536 debugging
logging rate-limit console 10 except errors
enable password ......
memory-size iomem 15
ip subnet-zero
no ip finger
no ip domain-lookup
x25 routing
call rsvp-sync
source-bridge ring-group 999
dlsw local-peer
dlsw bridge-group 10
interface Ethernet0/0
ip address 172.18.1.32 255.255.255.0
full-duplex
bridge-group 10
full-duplex
bridge-group 10
interface Serial1/6
description XM10008
no ip address
encapsulation x25
x25 address 20030055
x25 alias .*
x25 htc 32
x25 win 3
x25 wout 3
x25 accept-reverse
x25 suppress-calling-address
x25 subscribe lc0 two-way
x25 pad-access
lapb T4 5
qllc dlsw vmacaddr 4000.3622.6001 30 partner 4000.4468.0040
ip classless
ip route 0.0.0.0 0.0.0.0 172.18.1.251
ip route 172.18.1.0 255.255.255.0 172.18.1.223
no ip http server
snmp-server community public RO
x25 route .* source ^20030055$ substitute-source \0 interface Serial1/6
x25 route .* input-interface Serial1/6 substitute-dest 20030055\0 xot 172.18.1.253 xot-keepalive-period 20 xot-keepalive-tries 3
bridge 10 protocol ieee
dial-peer cor custom
line con 0
exec-timeout 0 0
logging synchronous
login
transport input none
line aux 0
line vty 0 4
Question: what to do to get the incoming call with a CUD=00 to be routed over XOT?
Regards.
s.jankowski
Level 4
Level 4
I am not aware of your problem, If a matching route is found, the incoming call is forwarded to the next hop depending on the routing entry. If no match is found, the call is cleared.
For more info : ttp://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120t/120t3/x25ca.htm#xtocid
Thanks a lot but I know very well what you are telling and I know also very well how to insert/remove/modify calling adresses as the URL you porived (with a missing 'h' in front) is telling. I already have configured succesfully more that 50 different routers with various xot traffic.
My problem is that there are some very weird things happening that are documented nowhere when using pad, qllc and xot on an x25 interface that I know. I am looking for help.
I have opened a case.
MARCELO MATURO
The diagnostic 68 indicates invalid facility. The xot insert in the call request paquet the same paramaters configured at the incoming interface
(x25 win 3
x25 wout 3
x25 accept-reverse )
maybe this parameters don´t agree witch the host that receive the call.
Marcelo
I don't know how to close this topic, but I don't need help anymore. I found the solution by opening a service request.
