zigzag traffic in asr9006
hello ,  we have ASR9006 , and we used bundle-ether for 12 member interface
i have many user's in the bundle-ether as subinterface and i have apply Qos for limitation bandwidth , and using PRTG for monitoring ,
our problem is , the traffic graph in PRTG show as zigzag traffic for VLAN senor traffic and QOS
Bundle-Ether1
  Status:                                    Up
  Local links <active/standby/configured>:   16 / 0 / 16
  Local bandwidth <effective/available>:     160000000 (160000000) kbps
  MAC address (source):                      e8ed.f341.dba4 (Chassis pool)
  Inter-chassis link:                        No
  Minimum active links / bandwidth:          1 / 1 kbps
  Maximum active links:                      64
  Wait while timer:                          2000 ms
  Load balancing:
    Link order signaling:                    Not configured
    Hash type:                               Default
    Locality threshold:                      None
  LACP:                                      Not operational
    Flap suppression timer:                  Off
    Cisco extensions:                        Disabled
    Non-revertive:                           Disabled
  mLACP:                                     Not configured
  IPv4 BFD:                                  Not configured
  IPv6 BFD:                                  Not configured
interface Bundle-Ether1.9
 description Cust-1
 service-policy output CUST
 ipv4 address 185.89.98.1 255.255.255.0
 encapsulation dot1q 9
policy-map CUST
 class class-default
  police rate 20000 mbps
 end-policy-map
0/RSP0/CPU0     A9K-RSP440-SE(Active)     IOS XR RUN       PWR,NSHUT,MON
0/RSP1/CPU0     A9K-RSP440-SE(Standby)    IOS XR RUN       PWR,NSHUT,MON
0/3/CPU0        A9K-36x10GE-TR            IOS XR RUN       PWR,NSHUT,MON
mohAmed khAdr
Your QoS rate limit is @ 20G which is hitting @ 21983
The output showing 16G. Peek graff never hit above 14000
So you still have room to push more traffic. I don't see anything unusual.
Do you see drops, crc, or re-xmission?
mohamed
thanks for reply
this dops result
sh drops
Wed Jun  2 20:47:02.988 UTC
                Node: 0/3/CPU0:
NP 0 Drops:
RSV_DROP_IPV4_DROP_NULL_RTE                                  1
RSV_DROP_IPV4_RXADJ_DROP                                     147
RSV_DROP_ING_LAG_NO_MATCH                                    168
RSV_DROP_QOS_DENY                                            29174834829
RSV_DROP_IFIB_TTL_CHECK                                      61844
RSV_DROP_PRRT_UIDB_MISS                                      15805
RSV_DROP_IN_L3_NOT_MYMAC                                     96844
RSV_EGR_LAG_NOT_LOCAL_DROP_CNT                               3
MDF_PUNT_POLICE_DROP                                         18676227976
MODIFY_PUNT_REASON_MISS_DROP                                 1
PUNT_FOR_ICMP_EXCD                                           7058
PUNT_TTL_EXCEEDED_EXCD                                       88391750
PUNT_ADJ_EXCD                                                544594400
PUNT_IPV4_ADJ_NULL_RTE_EXCD                                  18034365925
DROP_FRM_CRC_ERR_XAUI4                                       2361639
DROP_FRM_FRM_ERR_XAUI4                                       36634
DROP_FRM_CRC_ERR_XAUI5                                       2166010
DROP_FRM_FRM_ERR_XAUI5                                       86
DROP_FRM_CRC_ERR_XAUI6                                       1745970
DROP_FRM_CRC_ERR_XAUI7                                       126769981
DROP_FRM_FRM_ERR_XAUI7                                       12023529
DROP_FRM_CRC_ERR_XAUI8                                       1767897
DROP_FRM_FRM_ERR_XAUI8                                       182
DROP_FRM_CRC_ERR_XAUI9                                       2164843
DROP_FRM_FRM_ERR_XAUI9                                       14
DROP_FRM_RUNT                                                10804
PARSE_EGR_INJ_PKT_TYP_UNKNOWN                                16790000
PARSE_DROP_IN_UIDB_TCAM_MISS                                 3966900750
PARSE_DROP_IN_UIDB_DOWN                                      1004496
PARSE_DROP_IPV4_DISABLED                                     1631241
PARSE_DROP_IPV6_MCAST_NOT_ENABLED                            22407
UNKNOWN_L2_ON_L3_DISCARD                                     40719736
L2TP_ING_DECAP_VER_DROP                                      60
PARSE_DROP_PPPOE_NOT_ENABLED                                 5456
NP 1 Drops:
RSV_DROP_IPV4_RXADJ_DROP                                     125
RSV_DROP_IPV6_RXADJ_DROP                                     1
RSV_DROP_ING_LAG_NO_MATCH                                    127
RSV_DROP_EGR_LAG_NO_MATCH                                    1
RSV_DROP_QOS_DENY                                            29232583276
RSV_DROP_IFIB_TTL_CHECK                                      2914
RSV_DROP_PRRT_UIDB_MISS                                      16761
RSV_DROP_IN_L3_NOT_MYMAC                                     38748
RSV_EGR_LAG_NOT_LOCAL_DROP_CNT                               1
MDF_PUNT_POLICE_DROP                                         18294958677
MODIFY_PUNT_REASON_MISS_DROP                                 2
PUNT_FOR_ICMP_EXCD                                           5918
PUNT_TTL_EXCEEDED_EXCD                                       88452178
PUNT_ADJ_EXCD                                                482089389
PUNT_IPV4_ADJ_NULL_RTE_EXCD                                  17714864553
DROP_FRM_CRC_ERR_XAUI4                                       2069910
DROP_FRM_CRC_ERR_XAUI5                                       2324013
DROP_FRM_CRC_ERR_XAUI6                                       1612179
DROP_FRM_CRC_ERR_XAUI7                                       4654347
DROP_FRM_CRC_ERR_XAUI8                                       35216130
DROP_FRM_FRM_ERR_XAUI8                                       3458316
DROP_FRM_CRC_ERR_XAUI9                                       2287540
DROP_FRM_RUNT                                                3216
PARSE_DROP_IN_UIDB_TCAM_MISS                                 2297169024
PARSE_DROP_IN_UIDB_DOWN                                      449557
PARSE_DROP_IPV4_DISABLED                                     2731868
PARSE_DROP_IPV6_MCAST_NOT_ENABLED                            28602
PARSE_L3_TAGGED_PUNT_DROP                                    1
UNKNOWN_L2_ON_L3_DISCARD                                     416024
L2TP_ING_DECAP_VER_DROP                                      19
PARSE_DROP_PPPOE_NOT_ENABLED                                 45692
NP 2 Drops:
RSV_DROP_EGR_UIDB_DOWN                                       449
RSV_DROP_IPV4_RXADJ_DROP                                     84
RSV_DROP_ING_LAG_NO_MATCH                                    117
RSV_DROP_EGR_LAG_NO_MATCH                                    52
RSV_DROP_QOS_DENY                                            57612335824
RSV_DROP_IFIB_TTL_CHECK                                      5090
RSV_DROP_PRRT_UIDB_MISS                                      7079
RSV_DROP_IN_L3_NOT_MYMAC                                     1274
RSV_EGR_LAG_NOT_LOCAL_DROP_CNT                               53
MDF_PUNT_POLICE_DROP                                         9064780370
PUNT_FOR_ICMP_EXCD                                           22962
PUNT_TTL_EXCEEDED_EXCD                                       40259748
PUNT_ADJ_EXCD                                                228313713
PUNT_IPV4_ADJ_NULL_RTE_EXCD                                  8792360709
DROP_FRM_CRC_ERR_XAUI4                                       2518754
DROP_FRM_FRM_ERR_XAUI4                                       20062
DROP_FRM_CRC_ERR_XAUI5                                       190176026
DROP_FRM_CRC_ERR_XAUI6                                       169429813
DROP_FRM_CRC_ERR_XAUI7                                       2397108
DROP_FRM_FRM_ERR_XAUI7                                       249
DROP_FRM_CRC_ERR_XAUI8                                       3654658
DROP_FRM_RUNT                                                32
PARSE_EGR_INJ_PKT_TYP_UNKNOWN                                125401
PARSE_DROP_IN_UIDB_TCAM_MISS                                 5398734818
PARSE_DROP_IN_UIDB_DOWN                                      1872
PARSE_DROP_IPV4_DISABLED                                     6982484
PARSE_DROP_IPV6_MCAST_NOT_ENABLED                            36688
UNKNOWN_L2_ON_L3_DISCARD                                     7461951
L2TP_ING_DECAP_VER_DROP                                      10
PARSE_DROP_PPPOE_NOT_ENABLED                                 48964
NP 3 Drops:
RSV_DROP_EGR_UIDB_DOWN                                       445
RSV_DROP_IPV4_RXADJ_DROP                                     20
RSV_DROP_ING_LAG_NO_MATCH                                    120
RSV_DROP_EGR_LAG_NO_MATCH                                    2
RSV_DROP_QOS_DENY                                            48101762843
RSV_DROP_IFIB_TTL_CHECK                                      930
RSV_DROP_PRRT_UIDB_MISS                                      2610
RSV_DROP_IN_L3_NOT_MYMAC                                     794
RSV_EGR_LAG_NOT_LOCAL_DROP_CNT                               184
MDF_PUNT_POLICE_DROP                                         3073906297
PUNT_FOR_ICMP_EXCD                                           21060
PUNT_TTL_EXCEEDED_EXCD                                       8342311
PUNT_ADJ_EXCD                                                66826738
PUNT_IPV4_ADJ_NULL_RTE_EXCD                                  2997035196
DROP_FRM_CRC_ERR_XAUI4                                       2342109
DROP_FRM_FRM_ERR_XAUI4                                       13
DROP_FRM_CRC_ERR_XAUI7                                       151225284
DROP_FRM_FRM_ERR_XAUI7                                       6
DROP_FRM_CRC_ERR_XAUI8                                       3222414412
DROP_FRM_FRM_ERR_XAUI8                                       275059639
DROP_FRM_RUNT                                                162985
PARSE_DROP_IN_UIDB_TCAM_MISS                                 1833948559
PARSE_DROP_IN_UIDB_DOWN                                      1938
PARSE_DROP_IPV4_DISABLED                                     2628659
UNKNOWN_L2_ON_L3_DISCARD                                     3258848
L2TP_ING_DECAP_VER_DROP                                      5
PARSE_DROP_PPPOE_NOT_ENABLED                                 52686
NP 4 Drops:
NP 5 Drops:
FIA 0 Drops:
Total drop:                                                  15
Ingress drop:                                                15
Ingress sp0 crc err                                          7
Ingress sp0 align fail                                       3
Ingress sp1 crc err                                          2
Ingress sp1 align fail                                       3
FIA 1 Drops:
Total drop:                                                  24
Ingress drop:                                                24
Ingress sp0 crc err                                          4
Ingress sp1 crc err                                          8
Ingress sp1 bad code                                         6
FIA 2 Drops:
Total drop:                                                  40
Ingress drop:                                                40
Ingress sp0 crc err                                          10
Ingress sp0 bad code                                         13
Ingress sp0 prot err                                         3
Ingress sp1 crc err                                          7
Ingress sp1 prot err                                         1
FIA 3 Drops:
Total drop:                                                  7
Ingress drop:                                                7
