Zone based firewall and Bittorrent protocol
Nick Cutting
Good mroing chaps.
I have a security licence on a Cisco 1921. I do not have an application license.
I am using zone based firewall.
When treating a class map if I do a "normal" one - I am able to match on the P2P protocols:
Class Map match-any ALL-P2P-PROTOCOLS (id 25)
   Match protocol bittorrent
   Match protocol edonkey
   Match protocol gnutella
   Match protocol kazaa2
   Match protocol fasttrack
Now, as you know, you cannot use non inspect class-maps in an inspect Policy-map:
 class ALL-P2P-PROTOCOLS of type default is not allowed in policy-map PM_GUEST_TO_OUTSIDE_POLICY of type inspect
Now the problem I have, is that under and inspect map, I cannot use these protocols, they are missing!
In the cisco docs, they are there.
http://www.cisco.com/c/en/us/support/docs/routers/3800-series-integrated-services-routers/110388-ios-block-p2p.html
class-map type inspect match-any ALL-P2P-PROTOCOLS
1921(config-cmap)#   match protocol ?
802-11-iapp        IEEE 802.11 WLANs WG IAPP
  ace-svr            ACE Server/Propagation
  aol                America-Online Instant Messenger
  appleqtc           Apple QuickTime
  bgp                Border Gateway Protocol
  biff               Bliff mail notification
  bootpc             Bootstrap Protocol Client
  bootps             Bootstrap Protocol Server
  cddbp              CD Database Protocol
  cifs               CIFS
  cisco-fna          Cisco FNATIVE
  cisco-net-mgmt     cisco-net-mgmt
  cisco-svcs         cisco license/perf/GDP/X.25/ident svcs
  cisco-sys          Cisco SYSMAINT
  cisco-tdp          Cisco TDP
  cisco-tna          Cisco TNATIVE
  citrix             Citrix IMA/ADMIN/RTMP
  citriximaclient    Citrix IMA Client
  clp                Cisco Line Protocol
  creativepartnr     Creative Partnr
  creativeserver     Creative Server
  daytime            Daytime (RFC 867)
  dbase              dBASE Unix
  dbcontrol_agent    Oracle dbControl Agent po
  ddns-v3            Dynamic DNS Version 3
  dhcp-failover      DHCP Failover
  discard            Discard port
  dns                Domain Name Server
  dnsix              DNSIX Securit Attribute Token Map
  echo               Echo port
  entrust-svc-hdlr   Entrust KM/Admin Service Handler
  entrust-svcs       Entrust sps/aaas/aams
Do I need the application licences - so that I can use the Advanced NBAR protocol packs
Bilal Nawaz
Enhanced NBAR should be included in the security license. I haven't tried blocking bittorrent with zbfw. But an idea comes to mind, along with ZBFW you can apply a service policy on the outgoing interface to drop this kind of traffic.
policy-map PM-ALL-P2P-PROTOCOLS
drop
class default
permit
interface x/x (outgoing interface)
service-policy output PM-ALL-P2P-PROTOCOLS
Hopefully that would work. I haven't tested it myself though.
Hope this helps
Bilal
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
akimawik7
I had the same issue, and then came across this little tidbit of info:
  •  In Cisco IOS Release 15.3(1)T and later releases, the peer-to-peer protocols are deprecated. You cannot configure the peer-to-peer protocols with zone-based policy firewalls.
This is listed in the restrictions of this doc:  http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_data_zbf/configuration/15-mt/sec-data-zbf-15-mt-book/sec-zone-pol-fw.html#GUID-6ECF1303-423F-4809-9329-8876F79D2FA7
