AAA for SDWAN manager users
avdheshkumar
one of our clients wants to use Tacacs for users accessing SDWAN manager. i have not seen any option in the vmanage GUI has anyone done this . if yes, please guide.
Thanks in advance.
did you check cli
system aaa <<-
MHM
HI,
how do you manage sdwan-manager? Template based or CLI?
If template you have AAA template for the vManage (sdwan manager) and fill relevant fields in GUI.
For CLI below is base commands:
system
aaa
auth-order tacacs local radius
auth-fallback
tacacs
server [IP]
vpn [number]
secret-key [key]
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/system-interface/vedge-20-x/systems-interfaces-book/user-access-authentication.html
HTH,
Ruben Cocheno
@avdheshkumar
Here is the guide for it, which include ISE as well
https://www.cisco.com/c/en/us/support/docs/routers/sd-wan/215349-radius-and-tacacs-based-user-authenticat.html
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
dijix1990
You can use guide which mentioned @Ruben Cocheno, I've used this guide for configuring tacacs recently, but I needed to add new groups in the aaa feature for vmanage to set it more granulated. They are network operations and security operations because they weren't in the vmanage https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/system-interface/vedge-20-x/systems-interfaces-book/rbac.html
BTW, just found video guide https://m.youtube.com/watch?v=5g2d750vqkM
