Advantage of SDWAN over Legacy routing or Network
knaik99
why SDWAN is successful in market rather than traditional routing & switching network or legacy one ?
Please explain in simple words
@knaik99
 Cost. SD-WAN is expensive to deploy but permit huge cost cut by using the internet for routing traffic instead expensive MPLS
You can config 100 router via one step through one mange device
MHM
"WAN" section is almost fully automated. In case of Cisco, when you have DMVPN with VRF you need tunnel configuration, tunnel protection (IKE+IPSEC), routing etc. all from scratch. In case of Cisco SD-WAN, this part is done automatically and you are allowed just some changes if you need.
Plus, "WAN fabric" can be fully configured (LAN side, services+hardening) via templates which allows to push configuration to multiple devices at the same time. Detailed monitoring, additional troubleshooting tools, easy maintenance makes engineers life very easy thus you don't need "bigger" teams (cost). Plus, SD-WAN systems can be automated via APIs easily.
HTH,
