All possible values of state propery of "/dataservice/device" endpoint
brych126
I'm curious what is possible values of device state property got as result of executing request to "/dataservice/device" endpoint of Cisco SD-WAN vManage API. I cannot find this info.
Dan Frey
Its in the  yang schema of viptela-oper-system.
    leaf state {
      tailf:snmp-oid .54;
      type enumeration {
        enum blkng_green;
        enum green;
        enum yellow;
        enum red;
also in the VIPTELA-OPER-SYSTEM mib file
-- tagpath /system-status/state
systemStatusState OBJECT-TYPE
    SYNTAX      INTEGER {blkng-green(0),green(1),yellow(2),red(3)}
    MAX-ACCESS  read-only
    STATUS      current
    DESCRIPTION ""
    ::= { systemStatus 54 }
Dan, I'm very greatful for your response. May I kindly ask you provide info about all possible values of device status and state property got as result of executing request to "/dataservice/device" endpoint depending on API version? And what the difference between these 2 properties? I really need this kind information but unfortunately cannot find in anywhere. Thanks in advance.
