02-20-2023 12:52 PM
I'm curious what is possible values of device state property got as result of executing request to "/dataservice/device" endpoint of Cisco SD-WAN vManage API. I cannot find this info.
02-20-2023 06:15 PM - edited 02-20-2023 06:25 PM
Its in the yang schema of viptela-oper-system.
leaf state {
tailf:snmp-oid .54;
type enumeration {
enum blkng_green;
enum green;
enum yellow;
enum red;
also in the VIPTELA-OPER-SYSTEM mib file
-- tagpath /system-status/state
systemStatusState OBJECT-TYPE
SYNTAX INTEGER {blkng-green(0),green(1),yellow(2),red(3)}
MAX-ACCESS read-only
STATUS current
DESCRIPTION ""
::= { systemStatus 54 }
02-21-2023 01:33 AM - edited 02-21-2023 01:36 AM
Dan, I'm very greatful for your response. May I kindly ask you provide info about all possible values of device status and state property got as result of executing request to "/dataservice/device" endpoint depending on API version? And what the difference between these 2 properties? I really need this kind information but unfortunately cannot find in anywhere. Thanks in advance.
