Ansible Documentation SD-WAN
Jason Spring
So there is a ton of Ansible documented modules for ACI, IOX, XE, etc. I am having a tough time finding the Ansible Documentation for Cisco SD-WAN. Looking for the format similar to docs.ansible.com.
Can anyone throw me a bone?
stephli2
Hi Jason,
At the moment we don't have it on docs.ansible.com yet, but you can take a look at this repo (https://github.com/reismarcelo/sastre-ansible) in the meanwhile. This Sastre-Ansible repo helps users combine Cisco-Sastre Automation Toolset with Ansible Playbooks, making it easier to create and manage SDWAN network automation workflows using Ansible, and we are in the process of moving this git repo to under CiscoDevNet org and will submit it to ansible galaxy eventually.
