BGP template association
agredanoen
Hi experts,
I just created a BGP template on vManage and i understand it must be associated to service VPN since i want use BGP on the LAN side...
I just do not find how to associate this BGP template to the service VPN and or the desired vEdge device
could someone help me to do this?
hope you can help
Thnaks in advance
Best Regards
Enrique Agredano
Hi agredanoen,
Follow these steps to configure LAN Side BGP, i am using EBGP, you can use this template for iBGP for as well, all the process and steps will be same. Follow me here:-
1. Go to vManage dashboard, go to configuration-->Template-->Device Tab--> click  "..."on the cEdge or vEdge router on which you want to create and push the BGP template, below shows the screenshot for the same, i have circle the area with blue color where you have to click:-
Once you click on "..." select Edit the template  and template will be open, go to service VPN Tab, under service VPN tab right hand side you see additional VPN template options, under that select BGP (click on "+", to add ).
below the screenshot:-
Use the drop-down option under the BGP and click on Create Template:-
a template page will be open and there you have to fill information related to BGP, follow me below to fill the template:-
Template Name:- cEdge7_VPN1_BGP_Template ( you can give the template name your own)
Description:- cEdge7_VPN1_BGP_Template
go to the basic configuration Tab and Fill only which is required and leave all other options default or as it is:-
AS Number :- set Global and enter the AS number , i am using 65000 for AS number.
Address family:- IPv4 unicast
I have attached the screenshot follow the same:-
Go to unicast Address family Tab, and click on redistribute and click new redistribute and under protocol select global and OMP (to redistribute omp route into BGP) and click on add, below i have attached the screenshot:-
Go to Neighbor Tab click on New neighbor and fill the details which i have filled in below screenshot and click on add:-
once this all details will added also create one template for OMP for BGP to OMP route redistribution i have attached the template below :-
Capture7.JPGCapture8.JPGCapture9.JPGCapture10.JPGCapture11.JPGCapture12.JPGCapture13.JPG
And now you can push the template and verify the configuration.
kindly let me know if you still have any problem with SD-WAN.
Kindly hit helpful button, give comments and mark as a solve if this post has helped you.
Rohit Raj
Rohit Raj
5 Replies 5
ekhabaro
You need to reference BGP feature template now under service or transport VPN section of the device template.
Hi agredanoen,
Rohit Raj
Rohit Raj
Hi Rohit,
Thank you very much for taking teh tie for such detailed and accurate explanation
Best Regards
Enrique
Hi agredanoen,
Any time!!! keep posting your doubt, you will get answer for those. Happy learning!!!,
Kindly hit helpful button.
Rohit Raj
ekhabaro
Thank you
