Bidirectional packet capture for vEdge
saifulazlan
Hi.
I would like to know if vEdge 1000 support bidirectional packet capture in SDWAN Manager. vEdge is running version 20.3.7.1 while 20.9.4.1 for all controllers and SDWAN manager. Thank you
Azlan
Whatever I shared is "Packet Trace" tool which can show path-trace (what and where happening) with copy packet availability.
Whatever you shared is " Embedded Packet Capture" tool which captures packets at some points of flow with respect to device where you do capture.
For Packet Trace, bidirectional support is available from 17.8/20.8 (cEdge/vEdge).
For EPC, bidirectional support is available from 17.7 (cEdge only). For vEdge I don't see that support even with latest releases, just as feature it is supported from 20.6 releases.
HTH,
it is from 17.8/20.8. Since your router has lower release, it will not be possible:
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/Monitor-And-Maintain/monitor-maintain-book/packet-trace.html
HTH,
Hi Kanan,
Thank you for your response and clarification. Can i say that packet "capture" is based on packet "tracer" feature?
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/Monitor-And-Maintain/monitor-maintain-book/m-network.html#concept_dxx_5sm_3lb:~:text=Route%20Visualization.-,Capture%20Packets,-Table%206.
Bidirectional Packet Capture for Cisco IOS XE Catalyst SD-WAN Devices
Cisco IOS XE Catalyst SD-WAN Release 17.7.1a
Cisco vManage Release 20.7.1
This feature enhances the embedded packet capture functionality to support bidirectional packet capture through Cisco SD-WAN Manager.
Thank you.
HTH,
Hi Kanan,
I really appreciate the explanation. That implies that the only option left to me is to switch from vEdge to cEdge hardware in order to enable the EPC bidirectional packet capture feature.
Once again, thank you.
