cisco sdwan traffic rule- Loss correction FEC+PKT-DUP
andresvr
Hi Experts,
I am curious if there is a possibility to create a single traffic rule - data policy that uses both FEC and packet duplication for the same match condition. I was doing some tests and even making 2 rules on the same data policy, one with FEC always and the other  for PKT-DUP (in this sequence order), the packet was only applying FEC not PKT-DUP on all wan links available.
As the policies in vsmart work as an ACL in sequence style, I guess this is the normal behaviour, but i want to verify if there is a possibility to enable both features at the same time for the same service.
BR,
you should choose one of the action per access-list statement/ sequence. You can't have multiple actions.
And indeed, as you mentioned, since policy is evaluated from top to down, duplicate match with different action - has no meaning. Always, first rule is used.
HTH,
HTH,
