Branch vEdge and Controllers communications passing through a Datacenter vEdege
hamza.lemgaddar
Hi All,
I'm configuring a Labhome for Viptela SDWAN solution and I have a problem on communication between the Branch vEdge and the controllers that I configured on-promise on DC.
In attachment the archi diagram.
The problem is with the vEdge01-ANTA, all other vEdge are connected to on vManage.
The LAN interface of the vEdge02-PAN is with color private1 and the WAN interface is color mpls.
A default GW is configured on VPN0 on the vEdge01-ANTA to the WAN inteface of the vEdge02-PAN 192.168.215.9.
The WAN IP of the vEdge0A-ANT is routed for the Core of the 2 DC to the vEdge02-PAN lan IP 10.77.77.92.
I can' ping the WAN IP of the vEdge01-ANTA from all controllers.
But if I replace the vEdge02-PAN with a normal router, the ping pass and the vEdge02-ANTA pass UP on the vManage.
Is there anything that I should configure on the vEdge02-PAN to allowed this communcation?
Thank you.
hamza.lemgaddar
Any help please!!!
