cEdge( sdwan) 1161p- Port forwarding range
jgauchan
Am new to SDWAN and am trying to configure port forwading on our SDWAN- We have 10 Isr 1061 running IOS-XE.( Vedge, you have range, no issue)
I can't find any way to add range, I would do manually but the ports are in hundreds and there should be a better way of doing it.
We have Phone PBX that needs following port forwading
eg
Please see below for port forward numbers;
Point these to UCP IP Address: 192.168.1.XXX
UDP 5060 – 5060
UDP 6254 – 6254
UDP 7000 – 7015
UDP 7100 – 7115
UDP 7300 – 7315
UDP 10000 – 10239
UDP 5588 – 5588
TCP 8899 – 8899
TCP 7878 – 7878
Point the below to VOIM/VCIM IP Address: 192.168.1.XXX
 UDP 6000 – 6047
UDP 8000 – 8047
UDP 9000 – 9047
UDP 20000 - 20639
UDP 20640 – 20895
Please help me- Can't deploy SDWAN without this as This site will be HQ and Hub.
Thank you in advance.
Just been told by Cisco support team that there is no option to do this- Strange
I have to manually add this in router using cli template.
0 Replies 0
