Cisco Catalyst SD-WAN (onboarding cEdge Catalyst 8300)
Hello, I have a problem when I do the following:
When I onboarding cEdge I get the following error.
All other things like Certificates work fine.
5 Replies 5
you have physical hardware and this command is not supported (it is relevant for vedge-cloud ; csr1k ; c8k virtual).
You don't need this command during physical hardware onboarding, because of your device already has Cisco signed certificate. Just if you have enterprise CA option for controller certificates, then upload root certificate of controllers so while router authorizes controllers router will accept controller certificate.
HTH,
Thanks Kanan
It required adding the following command to all controllers (vBond, vSmart, and vManage):
request vedge add chassis-num xxxxxxxxxxxxxxxxxxx serial-num xxxxxxxxxxxxxxxxxxxxx
Now cEdge works as expected
Normally, you don't need this step. You should download serial list from Cisco PNP portal, upload to vManage and push certificate list to controllers via vManage GUI. Then all controllers will have authorization info (chassiss-num and cert serial number OR chassis-num and token).
HTH,
Hi Kenan, thanks again
Do you have any documents or guides for this process please, because there are no solid sources
This is onboarding guide:
https://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/SDWAN/sdwan-wan-edge-onboarding-deploy-guide-2020nov.pdf
Certifications related guide:
https://www.cisco.com/c/en/us/td/docs/solutions/CVD/SDWAN/cisco-sdwan-controller-cert-deploy-guide.html
HTH,
