Cisco cEdge with Firewall
RS19
Level 4
Level 4
Would like to check with you regarding the below point.
- Is it best practice to have hardware firewall in front of the Cisco SD-WAN devices as part of security ?
Is it best practice or recommended practice to put the firewall ?
RS19
Level 4
Level 4
Any inputs
It depends.. If you use NAT for a localised internet breakout, then I would suggest using a firewall. If you just plug the internet circuit into the router, have the interface be part of VPN 0 (Underlay), use it only to terminate the DTLS/BFD tunnels, then it "should be" secure. Just disable SSH, ICMP, etc on that interface. It's supposed to be a hardened interface, and they keep track of the packet based on the TCP sequence numbers which limits they chances of anyone hijacking the session / man-in-the-middle.
Double-check with your Cisco reps though and share your findings. It's been a while since I looked into the details around this.
Thanks.
I am planning to use Cisco ISR router with IOS XE image.
So wanted to check if IOS XE SD WAN functionality has robust firewall functionality ?
