Cisco Meraki Problem with transfer between VLAN
Jacob1990
Hello!
I have problem with transfer between VLANs.
I have Cisco Meraki MX64 and switch.
Transfer between VLANs (when I move files like .exe) is 30 - 32 MB/s is very slow ...
When I move these same files in this same VLAN I have transfer about 600 - 700 MB/s
IMO I must turn on L3 on switch, but ... i have some problems ...
My MX64 have IP address: 192.168.1.1
My switch have IP adress: 192.168.1.245
When I configure L3 like this:
I lost connection to SRV-VLAN (10.0.101.0)
What am I doing wrong?
5 Replies 5
balaji.bandi
check this thread may help you :
https://community.meraki.com/t5/Security-SD-WAN/MX64-Low-speed-over-interVlan-in-my-local-network/m-p/178566
if the configuration correctly done you should not lost that connect mentioned-  refer basic Layer 3 configuration guide from meraki :
https://documentation.meraki.com/Architectures_and_Best_Practices/Recommended_Topologies/MX_and_MS_Basic_Recommended_Layer_3_Topology
BB
Do I need to configure anything else?
Because i lost connection to SRV-VLAN (10.0.101.0)
This is not clear for us, Lost means  the device connected in the VLAN not working ? what is the issue ?
BB
Yes, device connected in the VLAN not working. I cannot ping and log on on RDP protocol.
The MX64 is rated for 250 MBit/s, so your observation is the expected behavior.
If you want to have SVIs on the Switch, you need a new transfer LAN between the switch and the MX:
  • The MS has a default route to the MX IP of the transfer link
  • The MX has a route to all VLANs on the switch with a next hop of the MS IP on the transfer link.
