Cisco SD-WAN OMP
RS19
Level 4
Level 4
I am using default feature template for the OMP
In the default OMP template, there is option for graceful restart timer value. I want to change the timer value
but when i tried to edit & change the default OMP value it is not allowing me to do ? The option is greyed out to change the value.
Wanted to check how to change the OMP graceful timer value from the vManage GUI .
hawaii
Have you changed it from default to global?
It is not allowing me to Edit & change it to Global.
Is it because this is the default template & this template is already assigned to other devices templates ?
