CISCO SD WAN USE CASE ON MPLS2L HUB SPOKE TOPOLOGY
Hi team
I wanted to ask a question about a design
  • Currently tcustomer has a total of 50 locations, they use a hub and spoke type topology (They are equipment 4331 and 4321, the customer wants to use their equipment until 2028.)
  • 25 with a layer 2 MPLS link that connects it to its DC that allows all access to the internet and some security feat...
  • 25 branches with at least 2 or 3 links (mpls, lte or inet).
Our question is specifically about these 25 branches with MPLS layer 2 links
In this case, is it necessary to upgrade the memories from 4GB of RAM to 8GB of RAM?
I think not, because since the security features will run on a hub (C8500) on the DC of the customer since they only have layer 2 point-to-point links, without the possibility of adding internet or lte...
2 Accepted Solutions
default RAM is OK if you will not use more features like DRE/ NGFW etc.
For normal routing it is enough.
HTH,
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/appqoe/ios-xe-17/appqoe-book-xe/m-integration-of-dre-with-cisco-sd-wan-tcp-optimization.pdf
You can use this chapter
HTH,
HTH,
Hello
Really, thank you very much for answering this, it helped me a lot, I was somewhat stuck here!
Do you know how much RAM I need for DRE?
Do you have any matrix?
HTH,
