Cisco SDWAN Forward Error Correction Loss correction threshold issue
HI Experts.
I know  the threshold value can be between 1% and 5% packet loss. Do you know whether the Cisco SDWAN FEC Loss threshold is for line packet loss or TCP packet loss?
  • FEC Adaptive—Only send Forward Error Correction (FEC) information when the system detects a packet loss.
  • FEC Always—Always send FEC information with every transmission.
  • None—Use when no loss protection is needed.
  • Packet Duplication—Enable when packets need to be duplicated and sent on the next available links to reduce packet loss.
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/policies/ios-xe-17/policies-book-xe/forward-error-correction.pdf
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
0 Replies 0
