Cisco SDWAN vManage GUI Not Working
pnkjmalik11
Hi There,
When i am trying to access the vManage from Google Chrome Browser its not accessible, giving error "This Site Can't be Reached". However, CLI mode is properly accessible from Putty.
Ping is successful from both end Windows CMD side & vManage CLI side.
Kindly find the below logs for your reference.
17 Replies 17
sorry for late reply,
can you make all vmanage vbond vsmart in same subnet (connect to SW) then you can also connect bridge cloud and try access vmanage
You didnt't answer questions about telnet output and resources, what are vCPU and RAM which you have given for vmanage instance?
HTH,
SamuelGLN
Hi @pnkjmalik11
Sorry for late reply. I had the same problem during my study lab. The first one was about the CPU and vRAM resources that wasn't enough. You can check this on the follow link: https://www.cisco.com/c/en/us/td/docs/routers/sdwan/release/notes/compatibility-and-server-recommendations/server-requirements.html
The second one occured when I did a vManage upgrade. I solved by creating a new vm and performing the restore vManage by utilization of a configuration-db backup. You can check this on the follow link: https://www.cisco.com/c/en/us/support/docs/routers/sd-wan/220305-standalone-vmanage-disaster-recovery.html
Best regards
******* If This Helps, Please Rate *******
