CLI command when viewing control connections
yoh_asakura29
Is there a CLI command that will show me the same ouput as below in vmanage when checking the control connections of vedge routers.
vSmart Control Connections (Expected: 4 | Actual: 2 )
sh control summary - just displays the current up/connected connection but it doesn't show how many control connections are expected to be UP.
expected/actual are applicable in case of edge router only. Because, edge knows its local interfaces - TLOCs , knows number of vSmarts and understand how many connections should be (expected) , how many in reality are formed (actual).
For controllers, especially for vmanage there is no such understanding. Each router can do one connection to vmanage at the same time.
You may use "show control connections" and if number of edges match number of routers in your SD-WAN fabric, then it means it is OK.
HTH,
HTH,
