CLI modification in sdwan
MohandevTiwari
I want do change in edge device via CLI mode... But I getting error device is in vmanage mode...
Imp:-
I don't to remove device from vmanage mode.
I want do change in vmanage mode only but via CLI command..
If this possible then please and please share the command , this will be very helpful for me....
For both
Viptela / iosxe
svemulap@cisco.com
Either the device is in CLI mode or in vManage mode.
Not sure, what you're trying to accomplish.
If you want to make changes to the node, move the device into CLI mode and make all the necessary changes.
To add to it:
If you want to push a specific CLI which is not supported in vManage GUI, you can do it with CLI-ADD-On Template
There is a CCO link with supported CLIs for CLI-ADD-On.
I want do change on device via cli only but device is in vmanage mode
I don't want convert device from vmanage mode to cli mode nor I want use any template for that just want make some changes via cli/putty
Please
When the device in vManage is, the config is LOCKED.
It is by design.
There is no option to make CLI changes and have the node still in vManage mode.
Then. single source of truth is gone.
At that time, having the vManage mode, doesn't make sense.
It defeats the original purpose.
For the thing that you're trying to do, it is probably best to leave the node w/o vManage mode.
So you have the flexibility to make changes via CLI, as needed.
