Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cloud OnRamp for Multicloud with MRF
Evgeniy
During the Multi-Region Fabric deployment at the border routers we have to configure some transport interfaces as part of the core region (Region 0) and some interfaces as part of the edge region (Region 1, 2, 3, etc..). But when you deploy Cloud Gateway routers  in Azure as part of CloudOn Ramp for Multicloud scenario, SD-WAN Manager creates the NVA (Network Virtual Appliance) in Azure with just two interfaces. So, how to make such Cloud Gateway router (C8000V) working as MRF Border Router? If I try to configure its one uplink as the interface that belongs to the core region, MRF finally does not work as expected. So, how to configure MRF with the Cloud Gateway router in Azure? Is it possible?
Thanks!
0 Replies 0
