Cloudops -- frequent session timeout
When logging to the Cloud SDWAN controller (vmanage).. and while doing some configuration i get frequent (around every 10 minutes) session timeout and i need to re-do the configuration... do i need to set the session timeout ?
The below is the url which i am redirected to when there is a session timeout....
https://default-755835.sdwan.cisco.com/logout?nocache=1729153673957&reason=sessiontimeout
ivances
Did you check the timeout settings on vManage administration settings?
Are you sharing the same username with more people?
The vManage timeout configured is 30 min (and there is no option to edit that)...  The username is not shared and there is only one login...
Anyways i am not seeing the issue today after the cloudops has been upgraded (today 19th they upgraded it)....
Thanks for your inputs
aarato
I have exactly the same issue. Any resolution found for this? OP
