control connection between vsmart and c-edge showing down
In my environment the control connection between vsmart and c-edge is showing down, handshake sate. With control connection with vm and vb is fine, also no packet drop or issue in isp link as all bfd session like 233 are showing up only control connection to vsmart is down
How can we check and do packet capture for udp port on c-edge.
