create VRRP on wan interfaces MPLS & INET
banoosh
we created VRRP on the sub inter for the lan side and its working fine but the WAN side its not, what is the good way to create VRRP on the MPLS AND INET interfaces for the both cEdge routers
What is not work?
Did you add track to vrrp?
I think what you see is bug but provide more detail to be sure
MHM
why do you use VRRP on WAN? OMP should handle overlay routing.
Just track OMP  or SIG tunnel (depending on implementation). Also, you can enable tloc-preference change so when router is active it increases tloc-preference so it becomes primary traffic entry both for ingress and egress.
HTH,
