Data Plane vs Control Plane Concepts clarification
nwekechampion
Level 3
Level 3
Hi Guys,
Just looking for clarification on the application of control plane and data plane concepts.
Would I be correct in saying that the the application of control plane and data plane depends on the architecture in place and not the protocols used?
For example is SD-WAN:
  1. underlay
    1. data plane ==> is CEF/FIB table on the edge routers
    2. Control plane (combined with dataplane per device) ==> BGP
  2. Overlay
    1. data plane ==> TLOCS, BFD, NAT and encryption, Colors
    2. Control plane (separation on VSMARTS) ==> IPSEC, OMP
SD-Access:
  1. Underlay
    1. Data plane ==> CEF/FIB
    2. Control plane ==> OSPF/ISIS/EIGRP
  2. Overlay
    1. Data plane ==> VXLAN
    2. Control Plane ==> LISP
Could anyone clarify, please?
2 Accepted Solutions
control and dataplane are not SDN specific terms.
Whatever related to user traffic flow it is dataplane. As you mentioned, devices use CEF/FIB to select path. Matching access-list doing some action /QoS /NAT /policing&shaping /encapsulation and encryption (also de- operations) of IPSec/ VXLAN etc. are data plane processes.
Control plane is needed to build forwarding plane - logic for data traffic (data plane). It includes any routing protocol, any negotiation between devices, LISP in SDA (as you mentioned) etc.
Example with IPSec (general and sd-wan case):
whatever done to build SA tunnels for user traffic is control plane in IPSec (Phase1 IKE /  Phase2 Quick mode) and plus protocols do health/ liveness check (like with dead Peer Detection in IPSec) are also considered control plane.
after that, when user traffic comes and IPSec does encapsulation&decapsulation also encryption&decryption - these are dataplane.
Please, note that there is no IKE in SD-WAN IPSec architecture, they relay on vSmart authentication. Devices advertise keys to vSmart, vSmart distributes key to other routers. Key distribution / rotation between controller (vsmart) and routers (edge devices) are control plane, but encrypting and decryption using these keys are dataplane operations.
Example with SDA:
LISP , yes, is control plane protocol.
VxLAN is data plane protocol (user traffic is encapsulated& decapsulation with VxLAN).
HTH,
sure. For underlay you may have, for example, BGP on WAN facing interface (transport) to connect to ISP or MPLS provider - this is control plane in underlay. Most data plane traffic is in overlay (in SD-WAN), but DirectInternetAccess traffic can be assumed data plane traffic in underlay.
Anything is related to protocol/ technique - CPU it is control plane. Anything is related to forwarding of user/data traffic - it is data plane.
HTH,
6 Replies 6
Example with SDA:
HTH,
Thanks @Kanan Huseynli ,
I am aware they are not SDN specific terms, I was just looking to understand how the control-plane-dataplane segregation applies to Ciscos SD-Access and SD-WAn environment.
The design CVDs explanation of the planes, for both technologies, are way too wordy for me, unfortunately.
However, I am still left with some unanswered questions.
1. does the overlay control and dataplane differ from that of the underlay (traditional network)?
2. is ipsec an overlay dataplane or control plane component in SD-WAN fabric?
Q1: could you explain it a bit?
Q2: we can say both. IPSec key distribution, key rotation, algorithm types are control plane. Whatever used in encryption&decryption actually on the data itself is part of data plane
HTH,
Thanks..
Q1.. Underlay has a data plane to build the physical network for Overlay, so it should still follow the rules of routing using rib/cef
So my question ==> Does the  control plane and data plane still apply in the underlay, that is, running on the same device (router/switch)?
HTH,
Thanks for your explanation @Kanan Huseynli
