DIA tracker in sdwan goes down after a couple of minutes
prateektanwar1
I have a dual router setup of ISR 11004g , primary link is DIA and the secondary is BIA,
we have a tracker enabled for DIA however after a couple of minutes the tracker goes down and because of that my traffic is going via the secondary link,
I have to manually remove and re add tracker again on the primary device to make it up but it goes down after some time,
Any suggestions on how to resolve this the only option I can think is of to remove the tracker config so that it will consider the link up and will follow the primary link path
0 Replies 0
