Cisco SD-WAN With SHDSL ATM Interfaces
Bassamfarghaly
Is Cisco SD-WAN support SHDSL ATM Interfaces as i tried to bring IPsec tunnel up with no luck although the control connection is up and stable
markcummins713
Cisco SD-WAN with SHDSL ATM interfaces combines Cisco's SD-WAN technology with Symmetrical High Bit Rate Digital Subscriber Line (SHDSL) ATM interfaces. This integration is graphic designer to enhance network connectivity and management, particularly when dealing with older networking technologies like ATM. The goal is to leverage SD-WAN's benefits, such as dynamic path selection, application-aware routing, centralized management, and improved security, to optimize network performance and security while accommodating symmetrical bandwidth requirements.
Bassamfarghaly
My question is it available to enable tunnel-interface on ATM interface and if not i tried through loopback but no way to bind this logical interface to the physical ATM interface
