DNA
How do you create a dhcp server in the Cisco DNAC
8 Replies 8
  Do you mean use the DNAC as DHCP server ?  This would be not possible.
What you can surely do is integrate DNAC with DHCP server. For example, you can integrate DNAC with infoblox. The scope created on the DNAC will be replicated on the Inforblox DHCP server.
What about adding the dhcp server address onto the dnac
DHCP as client? Dont believe is possible also.
Now, you refer to a DHCP on the fabric device  then you need to integrate the DNAC with a DHCP server first.
DHCP as a server
I have little info. But I think yoh can use pnp to interconnect dhcp to dnac.
How would I import the dhcp server address in the Cisco dnac
The attached file will show you step by step
Leo Laohoo
What is the exact model of the DNAC appliance?
How many devices (switches/routers/WLC, APs, etc) are currently being monitored?
Please elaborate what, exactly, is the intention?  Is the intention to completely wipe the DNAC appliance and turn it into a dedicated DHCP server or run a DHCP server alongside DNAC?
