DTLS connection im Vmanage
himanshudwivedi
I am new to SDWAN
I have 1 VManage, Vsmart and Vbond and all are showing active. But when I execute command in Vmanage it is showing 4 DTLS connection with vBond in which Peer are 0,1,2,3 all are showing up but System Ip is only showing in 0 Peer, in 1,2,3 it is showing 0.0.0.0 , so what does it mean why it is making 4 connection.
Same thing happening with Vbond it is showing 4 DTLS with Vmanage, with all Peer 0 and showing Vmanage system ip, why is this happening or it is default behaviour.
svemulap@cisco.com
hi,
We will have (d)TLS connection per core.
If you more closely, the port will be different
Something like 12346, 12446 and so on.
It is a way to distribute the load across the cores, so control connections are spread across and not pinned to one core.
The SD-WAN CVD link has more details. Link below:
https://www.cisco.com/c/en/us/td/docs/solutions/CVD/SDWAN/cisco-sdwan-design-guide.html?dtid=osscdc000283#FirewallPortConsiderations
