Duo MFA integration for Cisco vManage
swpp
hello.
We must to Duo MFA integration in Cisco vManage multi-tenant mode.
Has anyone implemented it?
Looking at the link and photo below, it is said that Duo MFA is supported starting from vManage 20.12.x version.
But, after changing to vManage multi-tenant mode, the settings menu disappeared.
Release Notes for Cisco Catalyst SD-WAN Control Components Release 20.12.x
To integrate Duo MFA in vManage multi-tenant mode, is there any way other than applying a metadata file from the Identity Provider Settings (IdPs)?
I would appreciate it if you could reply to me.
Thank you.
Lei Tian
Unlike SSO, the Duo MFA integration actually doesn't require metadata file from IdP. It integrates with Duo directly from vManage.
Lei Tian
hello, Lei Tian
Lei Tian
Hi, I don't see that's mentioned in any existing release note, but there is some MT feature updates in 20.15 release.
HTH,
Lei Tian
