Enable BGP ECMP (Equal Cost Multi Path) with vEdge Template
shlomyb
I have at my lab vEdge running version 20.9.3.1 with 2 WANs.
from both I'm getting over BGP default route -
vEdge3# show bgp routes 150.1.1.0/24
bgp routes-table vpn 0 150.1.1.0/24
info 0
nexthop 150.33.0.2
weight 0
origin incomplete
as-path "200 200"
path-status valid,external
tag 0
ospf-tag 0
info 1
nexthop 10.33.0.2
weight 0
origin incomplete
as-path "100 100"
path-status valid,best,external
tag 0
ospf-tag 0
I thought that I've chosen the right Template modification but reality shows I'm missing something.
when looking at the applied configuration -
vpn 0
router
bgp 12345
address-family ipv4-unicast
maximum-paths paths 2
neighbor 10.33.0.2
no shutdown
remote-as 100
neighbor 150.33.0.2
no shutdown
remote-as 200
when looking at the routing table only 1 is valid instead of both.
how do I enable both ?
2 Accepted Solutions
Harold Ritter
Hi @shlomyb ,
By default, IOS will not load balance between two paths received from different ASN.
Try adding the following command to your BGP configuration.
router bgp 12345
bgp bestpath as-path multipath-relax
shambhu.kumar
vpn 0
router
bgp 12345
best-path
Harold Ritter
Hi @shlomyb ,
router bgp 12345
first of all thank you for your help !
just to be sure - I'm talking about vEdge and not cEdge - therefor I'm not sure it is right to call it IOS.
can you refer me what to change over the Template using the vManange ?
shambhu.kumar
vpn 0
router
bgp 12345
best-path
thank you very much for you patient and help !
much appreciated !
