IQDF SD-WAN C8300 Scalability Testing Methodology
MATU102424
Hello, I am looking to understand what IQDF relies on in the Datasheet performance/scalability numbers for the Catalyst C8300 and other routers.
The results I am interested are for the IQDF Mix, "** IQDF traffic pattern: IPSec + Quality of Service (QoS) + Deep Packet Inspection (DPI) + Flexible Netflow (FNF)".
My questions:
1. What are the default IQDF features (e.g. AAR, NBAR, etc.) enabled in the configuration that were enabled and tested as part of the scale testing?
2. Does the mix include NBAR and if so, for which mix (e.g. DPU, FNF, etc.)
Thank you,
M
balaji.bandi
Personally my views, you need to configure everything in test best and start doing your regression testing,
I am sure cisco Lab may have done that and produced the results based on that outcome.
But depends on your requirement you can confgure and simulate that if you like on the Test Lab as acceptance before you put them in production, there are enough documents available each area how you can configure and achieve.
https://www.cisco.com/c/en/us/support/routers/catalyst-8300-series-edge-platforms/products-installation-and-configuration-guides-list.html
BB
