ETHERCHANNEL CONFIGURATION ON MERAKI MS255
DrX1994
Hello  everyone, I am tasked with migrating network and all its services from Cisco C9300 access switches to Meraki MS255 switches. The configuration script has an etherchannel configuration on it and the customer wants it to work on Meraki MS255 just as on the C9300.
Is it possible to configure portchannel between the MS255 and the CORE switch NEXUS C9500 switch?
svemulap@cisco.com
Hi DrX1994 - Looks like you posted your query to wrong channel. This channel is for Viptela/Cisco SD-WAN solution. (not Meraki) HTH
